Sponsored by: CARiD
Headlight gears and electrical problems.
Old Jul 31, 2017 | 08:32 AM
ShovelMan's Avatar
Default Headlight gears and electrical problems.
The video says all. I did the 180° temporary fix and that moved the grinding noise to when the headlights flip up. Before the fix, the motor had a 5 second grind-session during headlight flip-down phase.
NOTE: Headlights are going up because I'm pressing unlock on my keyfob.
Also, I'm not sure if it's related but my driver's side power Lock function does not work. Unlock works. Lock and unlock works on passengers side.
Old Aug 1, 2017 | 08:43 AM
ShovelMan's Avatar
Solved: The power lock button on the driver's side was on its way out. Functionality works but the button/switch makes no contact with to make the doors lock.
Headlight issue is ongoing. Ordered a brass gear and it should arrive here this week.
Old Aug 1, 2017 | 08:46 AM
bleepster's Avatar
well - how was it solved???
