Sponsored by: CARiD
Oil 99 z28 SS
Old Aug 13, 2017 | 08:05 PM
Johnny Redfearn's Avatar
Default Oil 99 z28 SS
Hey guys wanted to see if your cars use oil? I'm talking about 1/2 quart or so every 1000 miles. I seem to be adding oil about every 1000 -1500 miles maybe 1/2 to a quart does this seem normal? My car has been rebuilt with pretty healthy cam, 243 heads, injectors and typical upgrades
Old Aug 13, 2017 | 08:14 PM
HCI2000SS's Avatar
Mine uses about 1/2 quart every 1000 or so miles. I wouldn't say abnormal but it just depends on things like the type of valley cover used and how the pcv is setup. Also things like bearing clearance are a factor as well
Old Aug 13, 2017 | 08:16 PM
It's a new build, I will check the PVC valve. Might be a dumb question is there a way to tell if pvc is bad?
Old Aug 13, 2017 | 08:26 PM
HCI2000SS's Avatar
Never really have seen the valve itself go bad. Usually hoses and whatnot. If you suspect in any way that there is an issue I'd just replace. They are like 10 bucks or less
Old Aug 16, 2017 | 08:01 PM
RockinWs6's Avatar
normal, mine has used oil for the past 150k miles.................
