Rewiring headlight harness?
Should I have not done it this way? Did I not hook up the correct wires together? I am 99% sure I hooked up each wire that was across from it in the connectors. Any help is greatly appreciated, thanks.
The motor should not run continuously. There is a timer circuit in the headlight module that cuts that action off. So, if the motor is running continuously, I would guess that you have the motor re-wired to constant power (like the headlight power) and not the proper motor power feed wire.
In the connector, coming to the motor, there is a common ground for the headlight bulbs, power for the low beams, power for the high beams, and two wires for the head light motor. (If you log on to Autozone.com and register, you can access the car's electrical schematic and match the wire colors.)
The two wires for the motor reverse when the motor controller signals up or down, so if the wiring is crossed the motor is only going to go one way and it would keep running if it has a constant source of power.
I am lost. It looks to me like every wire is hooked up correctly and has power going to the motor. Could it be the headlight control module not sensing the correct load so in turn not moving the motor?
The two wires reverse polarity when the lights are supposed to go up or down. If they aren't doing that at the connector, then you could have some of the motor controller problems discussed later in the thread.
I ordered a new/used one and hopefully its here by Saturday.
Could having one head light up and the other down have caused this?
