Anyone notice vibration after umi torque arm relocation install
I just installed umi 4l60e torque arm relocation mount in my 98 camaro now I getting a bit of vibration in the floor on cold start up for 10 seconds then it goes away .. just wondering if anyone else had this.. im running stock transfer mount
Moderator
Received 1,852 Likes
To clarify, you went to a tunnel mount?
I Have the one for the TH350, and I have no vibration. I can tell you though that your y-pipe/x-pipe is nearly impossible to route around the torque arm mount bracket on the crossmember, so that might be your problem? A lot of guys go with a custom y-pipe/xpipe setup I'm learning.
