Need info
I used a OB2 scanner to scan for codes but nothing was found I'm looking for suggestions .
The car has a BTR stage 2 cam , BTR lifter, rods the heads have had work a fast 92 mm intake and throttle body a new MAF , 42 lbs injectors New fuel pump it's been tuned and EGR valve delete I know I'm forgetting stuff .
And again the car has been running great until today . The motor has approximately 4000-5000 miles .
Spark missing can be bad plug, wire, coil, or crank and cam signal issues.
Rich is MAF, MAP, or O2.
Lean or no fuel is filter, pump, or regulator.
If it's rich or down on spark in a couple of holes you can run it some more and the scan tool will start to be more help. If it is lean you don't want to run it for risk of damage. If it is really rich that can be bad also.
I'm assuming that this has to be an electrical issue right ? I'm thinking and correct me if I'm wrong if it was mechanical problem it wouldn't have just died on me so after I changed the plugs I did try it again and it was a little bit better but still missing like hell and would try to idle at about 400-500. It scares the hell out of me because it sounds like it going to come apart .
Thank you for your help bud anything else let me know
