High Idle after jumpstart
I connected a charger to it for a couple hours at 40amps, at first it stalled out, and when I started it again it stayed running, but the idle was high, around 1500rpm, even after warming it up and driving around for a bit.
What's going on? was the battery still weak and the engine was revving higher to try to recharge it? I was thinking since the battery died the ecu had to relearn proper idle and that's why I drove it around for a bit, but it was still idling high when I pulled back into my driveway. I have the charger hooked up to the battery again on slow charge and am going to come back later and see what happens. Thanks for any input.
Second, charging any battery for a couple of hours at 40 amps is excessive. Most home chargers will give you a short burst of up to 50 amps for a jump start, but then only charge in the range of 2-10 amps depending on settings and charger type.
Third, if the battery was truly dead then the PCM will in fact have to relearn all the soft parameters. You might have some idle weirdness at first, but it shouldn't be stuck at 1500rpm for a long period unless something else is going on. Regardless, the condition of your current battery is likely questionable.
So after running it for about 10-15 minutes I hooked the charger back up to it on slow charge, and the light is no longer green. It's orange telling me that the battery is not fully charged. It's been about 20 minutes now and the light still hasn't gone back to green. I would expect the light to be green right away telling me the battery is full after charging all day and letting it run for 15 minutes. The only reason I could think of why it would have to charge up for a bit again would be if there was a problem with the charging system/alternator. Seems to me like it's not doing a good enough job recharging the battery? Is this a reasonable conclusion?
The posts looked pretty good on my battery but I will try cleaning them and seeing what happens. Thanks.
This is the time of year where weak batteries get exposed, so if your battery is over 5 years old, it's probably worth changing it out - no matter if it tests "good" or not. Even if your problem is elsewhere, you are on borrowed time with that Die Hard.
https://www.youtube.com/watch?v=BT_UzRpcPYg
http://www.sears.com/ue/home/diehardfaq.html#03
"How do I determine the age of my battery?
A decal placed on the side of all DieHard batteries provides the month and year each battery was shipped from the plant. The letter corresponds with the month, starting with “A” for January, “B” for February etc. The number represents the year with “7” standing for 2007. For example, A/7 would be January 2007."
At any rate it's looking like I need to replace the battery.
Regardless, I would replace it if it's not properly taking or holding a charge. FWIW, in regards to my post from yesterday, our spare daily driver just sat outside for two weeks, unused, in temps ranging from -10°F to about +15°F, and it fired up and ran just fine today. They shouldn't dump a charge in a week or two, even in this cold, unless the battery is weak, poorly charged to begin with, or there is a drain somewhere (which is somewhat typical for certain new cars even if nothing is "wrong", but not with 4th gen F-bodies.)
I would echo RPM Ws6's comments. We do have other threads about batteries, which have gone this long.
If you have a $100, 7 year battery in it's 6th year of life, it's depreciated to being "worth" $12 at that point. Consider the increasing risk of getting stranded on top of that and one should be able to make a decision.
