Sponsored by: CARiD
Power Steering Return hose needed
Old Jan 19, 2018 | 11:33 PM
dave900575's Avatar
Default Power Steering Return hose needed
My 2000 Camaro 5.7 L V8 needs both the pressure and return lines for the power steering. i just had a reconditioned steering rack installed. It seems the only return hose available is for the 3.8L.
Does anyone know if it is possible to adapt the 3.8L version for the 5.7L?
Old Jan 20, 2018 | 11:51 AM
Crf450r420's Avatar
The return is low pressure so it can just be oil rated 3/8" hose with clamps. If you want better you can get AN adapters from Turnone and probably earl's to run braided nylon or stainless lines.
Old Jan 21, 2018 | 09:42 PM
wssix99's Avatar
Save the manuals!
I would think so. The AC Delco part (36-361130) for the 3.8 is a generic piece. The OEM hose on the 5.7 was just a metal tube that attached to the rack and the hose that came off of it was regular and non-molded.
If the metal part of your original hose is fine, you may also be able to use this method to replace the crimped fitting and add a new piece of rubber hose: https://ls1tech.com/forums/general-m...-fix-pics.html
Old Jan 23, 2018 | 11:50 AM
ss.slp.ls1's Avatar
When I needed one the store I went to was out of stock, so I just got a length of rubber hose (3/8" I think) and cut it to fit and clamped it at both ends, worked great.
Old Jan 29, 2018 | 03:15 PM
Schnell's Avatar
dave900575 what did you end up doing? I have 99 Z28 and having the exact problem know of I need to replace low pressure power steering line.
Old Feb 4, 2018 | 11:28 AM
capelajc's Avatar
Interested in what you ended up doing as well, my return line was hitting the pulley at some point and I noticed it's leaking. I took it off this morning and went down to the local Autozone and they didn't have the same size hose. But the bends in it have me concerned if I just get a length of hose.
Old Feb 10, 2018 | 06:59 PM
capelajc's Avatar
I Went down to NAPA today and just got a same length of hose and replaced mine. Even with the noticeable bends from factory it was no problem
