broken starter thread for the starter bolt
Hi Guys, I have an issue about the starter mounting thread that the starter bolts thread into to mount the starter. I dont know how to post the pic but, the place where the bolt threads in has broken off the corner of the block.
Whats the repair, can i relocate the starter bracket or mount it in another spot so it connects with the flywheel?
someone told me its a common thing for it to chip off the corner of the LS1 block. I don't know if thats true but any advice on how to get the starter mounted would be a lifesaver. Thanks
Save the manuals!
This is unfortunately a common problem. The fixes I've seen are to either professionally weld the block or get a special bracket to work around the issue. (There are a number of options out there - some companies price gouge and take advantage of the situation...)
If you search this site, you'll also find some members who have fabricated their own brackets.
