Sponsored by: CARiD
WS6 has no balls
Old Apr 12, 2018 | 08:32 PM
Crf450r420's Avatar
spray bottle with some salty water at night while motor is running can show if there is an arcing issue.
Old Apr 23, 2018 | 02:27 PM
INTIMIDATOR_LSX's Avatar
Update***
So I did a fuel pressure test yesterday..Idle PSI was 58. Under load I would regularly see it drop to at least 52-54 PSI on pulls but I did see it drop below 50 a couple times WOT.. Didn't get a chance to check the regulator yesterday tho
Old Apr 23, 2018 | 03:53 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Originally Posted by INTIMIDATOR_LSX
Update***
Looks like you've found the problem. Now it's just a matter of determining if it's the replacement pump itself that's failing, or some other part of the original stock assembly that's causing the issue.
Old May 4, 2018 | 06:39 AM
thake618's Avatar
Originally Posted by RPM WS6
Just an FYI, there isn't really much performance difference between the 2.73 and 3.23 rears in the 4L60E cars. I've owned two of each. The 2.73 cars actually aren't much slower, 1-2 tenths/1-2mph with the stock torque converter (less with a 3500+ stall). It wouldn't make the kind of difference you're talking about.
On the other hand, if you put a 2.73 rear with the T56, that might feel pretty sluggish, especially with a cam, in the lower rpms. But I don't think you said anything about changing the rear/gear during this process (or did I misunderstand?)
so a gear swap from 3.42 to 4.10s would accelerate harder? sorry to chime in lol
