Sponsored by: CARiD
WS6 has no balls
Old Apr 6, 2018 | 06:55 PM
INTIMIDATOR_LSX's Avatar
Default WS6 has no *****
What's going on people.. Little background on this car.. A few years ago I bought a crashed 02 WS6 with a 4L60e off my friend and transplanted the drivetrain minus the rear end into a 01 V6 5 speed firebird with the performance package with the 3.42 gears.. Hated the auto so I ended up swapping in a t56 a month later. That car ran like a beast. Raced a new coyote at the time and it was neck n neck.
Anyways, time went on and I bought a Trans Am roller to swap everything back over including the rear end from the V6 body, as I was told the rear in the TA roller was no good. Ended up selling the car to my brother in the process so we ended up cam swapping it and doing LT's, full exhaust etc. Tune time comes along so I'm driving conservatively to the shop but I still get on it a little bit like anyone else would and I was like damn this thing does not move like it used to stock, but I wasnt really getting into to it so I brushed it off because it wasn't tuned yet.. Went to the tune shop and had fuel problems. Ended up driving home and the fuel pump died in front of my driveway after sitting in traffic for an hour, so I got lucky as hell on making it home lol.
Changed the fuel pump to a Racetronix 255lph and also the fuel filter, so all was good fuel pressure wise. My brother took it back for a retune and then there was a problem with the MAF so the tuner just tuned it SD. Ended up dynoing in at 409rwhp. Yesterday I asked my brother if I could drive it and holy ****.. I got on it in 2nd gear and I just turned to my brother confused as hell lol. The car literally does not pick up at all like it used to in stock form. No torque whatsoever. I feel like my 1998 Camry 4 cylinder would drag that thing lol.
Any ideas on WTF is wrong with this car? Car literally has the Mustang effect. Loud as hell but doesnt go anywhere. I'm stumped on this one.
Old Apr 6, 2018 | 06:59 PM
HCI2000SS's Avatar
Are you able to monitor the afr?
Old Apr 6, 2018 | 08:05 PM
Not at the moment.. Why, what are you thinking??
Old Apr 6, 2018 | 08:15 PM
HCI2000SS's Avatar
Well being able to monitor afr would be a good start to see if it's running dangerously lean or rich. That is always a good thing to know to begin with
Old Apr 6, 2018 | 08:50 PM
Yea I know what you mean. So far I’ve checked the spark plugs and they aren’t white or black, they look normal and there’s no black smoke or anything revving or under load. Also at idle there’s plenty of water dripping out of the exhaust. Car sounds healthy as hell it just doesn’t move. That’s why I’m having trouble pinpointing this problem.
Old Apr 7, 2018 | 02:31 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I agree on checking fuel trims/AFR. If that's not possible at the moment due to lack of a scanner/gauge, then maybe you could at least check fuel pressure under load? Make sure the new pump isn't giving up during a loaded WOT situation.
Also, how is the clutch?
Old Apr 7, 2018 | 08:01 PM
TA_Freak's Avatar
Valve timing? Was the cam degreed? Sounds like the cam is retarded.
Old Apr 7, 2018 | 08:17 PM
RevGTO's Avatar
Pontiacerator
The above suggestions are good. Since you can't log yourself, take it back to your tuner and have him log afr and fuel pressure as the rpms climb.
What are the specs of your cam? At what rpm are you shifting at WOT ?
Old Apr 7, 2018 | 09:05 PM
If it was leaning out while driving wouldn’t I get a code for that? I’ll run the check ASAP. Idk if I made it clear with the original post but I’m saying the car doesn’t have the torque it should just driving normally, not just a WOT situation.
Old Apr 7, 2018 | 09:08 PM
If the Cam was retarded it wouldn’t have made those numbers.. made those numbers with stock 241’s and LS1 intake.
Old Apr 7, 2018 | 09:16 PM
BTR Stage 3. I put the same cam in my car and it’s no comparison. I used the same tuner for my car..best in my area. Anyways, when I drove it the other day I didn’t even bother taking it to redline. My bro said he raced a V6 Challenger and he said he barely beat it. that’s why I jumped in the car to see what was going on..
Old Apr 7, 2018 | 09:20 PM
I’m really thinking it’s a problem with the rear end because I had a A4 Z28 a couple years ago too and it had the same type of acceleration because it had 2.73s. That car was slow as hell too
Old Apr 7, 2018 | 09:25 PM
RPM WS6's Avatar
You wouldn't necessarily see a code for this. I've encountered several members lately who've experienced some major power loss from low fuel pressure under load and they weren't seeing any lean codes (even with a stock tune).
Based on this:
...I got on it in 2nd gear and I just turned to my brother confused as hell lol. The car literally does not pick up at all like it used to in stock form...
...my impression was that it just felt bad under a WOT pull. But, it could still be fuel pressure related, perhaps the new pump was faulty or some other issue has developed with the stock bucket (assuming you just did a pump only swap).
Is there any chance the clutch is failing/suspect? I know it made good dyno numbers, but perhaps it was on the border of being marginal?
Old Apr 7, 2018 | 09:34 PM
RPM WS6's Avatar
Now I'm confused, I thought it received the 3.42 rear from the other setup?
Just an FYI, there isn't really much performance difference between the 2.73 and 3.23 rears in the 4L60E cars. I've owned two of each. The 2.73 cars actually aren't much slower, 1-2 tenths/1-2mph with the stock torque converter (less with a 3500+ stall). It wouldn't make the kind of difference you're talking about.
On the other hand, if you put a 2.73 rear with the T56, that might feel pretty sluggish, especially with a cam, in the lower rpms. But I don't think you said anything about changing the rear/gear during this process (or did I misunderstand?)
Old Apr 7, 2018 | 10:11 PM
TA_Freak's Avatar
Sure it could .. the power would just come in later ... RPM wise.
Old Apr 8, 2018 | 01:44 AM
Based on this:
Yea I’m going to do a fuel pressure test under load this week and report back. I did do a pump only swap. Clutch is a >2k mile LS7 setup. I put that in when I did the T56 conversion. I want to bank on it being a fuel issue then because the new pump and the car being cammed is the only difference from when I pulled it out of the other car and put it in this one. Same engine, same t56 and same rear end.
Old Apr 8, 2018 | 01:49 AM
Damn that’s interesting. I thought it would be a bigger difference than that. I was just stating that I had a camaro with that rear end lol I did keep the 3.42 rear in this car.
Old Apr 8, 2018 | 02:00 PM
RPM WS6's Avatar
Gears "feel" like they do a lot more than they actually do. It takes some pretty significant ratio changes to really effect much in the way of performance improvement in terms of ET and such. For example, you'd have to go from 2.73 all the way to 3.73 in a 4L60E car to see an improvement of ~3-4 tenths or so (stock torque converter), and that gain gets cut in half if you optimize the stall speed first (meaning 3500+ for an LS1/4L60E combo).
4L60E has a more aggressive internal first gear ratio than a T56 (3.06 vs 2.66), so the auto cars don't need as much rear gear to get similar mechanical advantage throughout 1st gear as the M6 versions (plus torque multiplication of the converter at launch for an auto). That's why I mentioned that a T56 with a 2.73 and a cam that's shifted the powerband higher could in fact feel pretty sluggish at low rpms. But, that's obviously not the case here since you said it still has the 3.42s and the lack of torque seems to exist in any gear/rpm, WOT or not.
Old Apr 8, 2018 | 08:19 PM
Crf450r420's Avatar
Check if each exhaust is getting hot as and easy spark check. One exhaust part not hot, check for spark there. Then check fuel pressure. Start with simple things you can do with cheap tools easily. Get more advanced after you go over the basics, fuel, air, spark, and compression.
Old Apr 10, 2018 | 10:00 PM
sschoeffler's Avatar
Sometimes you can have a plug wire that is bad, but each tube still gets hot. Been there done that. My problem was an arcing wire due to it being melted on the bottom side close to the header. Wasn't visual without pulling the wires. Ive seen the same issue when the plug wires are not fully seated either on the plug or in the coil. Wires had less than 1000 miles. If you find one melted, wrapping it with silicone or electrical tape wont work.
