IAC idle issues
The Problem: occasionally when letting off the clutch from a light throttle application the engine stalls or comes close to stalling. Has been tuned recently with a H/C/I install.
The diagnosis: myself and the tuner have been working on it, when the stall happens nothing shows why it should be happening. The Idle Air Valve is showing an open status that is being commanded so we thought it might be the valve itself. Well a replacement valve has arrived and although the symptoms are less frequent it still happens randomly.
If the valve, vacuum, and tune have been ruled out, what else could be there culprit? fault MAP sensor?
The whole thing is weird, it's starts right up and idles fine. The IAC follows perfectly from WOT applications, it's only the light throttle applications and doesn't happen all the time.
