Sponsored by: CARiD
Backfire at idle
Old May 2, 2018 | 10:45 AM
Kevinr8732's Avatar
Originally Posted by wssix99
Right, that's not normal. The typical occurrence sounds like a fire cracker being thrown out the tail pipe.
If there is a detonation before the tail pipe, then there must be air and fuel being dumped into the exhaust. I would also check for exhaust leaks to make sure they aren't in play here. Otherwise, you could have some rich cylinders and lean cylinders.
could it be the PCM? Because I did have some wires from the harness laying on my headers that was Burnt when I say them.
Old May 3, 2018 | 06:29 AM
wssix99's Avatar
Save the manuals!
That could be a problem if sensor wires were damaged. Did you fix them? Did you scan the car for codes?
Old May 3, 2018 | 07:08 AM
ZEN357's Avatar
I would change the spark plugs. Maybe put a good set of E3 Diamond Fire plugs in it.
Old May 3, 2018 | 10:19 AM
Kevinr8732's Avatar
spark plugs changed. I’m waiting on my pcm to come in and I bought some new injectors?
