Sponsored by: CARiD
Dr44 alt
Old May 6, 2018 | 06:32 PM
xenergyx's Avatar
Default Dr44 alt
I have a HO dr44 alt 320a or 400a from Ohio generator that I had running in my my 02 TA. It was mounted low d/s the pos post was rather long and after a time I assume my motor mounts wore down and either I hit a large bump or whatever it touched my p/s line and arced a hole into the line obviously their was some electrical haywireness with shorting. I put the small stock alt back in and rearranged the orientation of the pos post so it won' be near the lines . Now I The HO alt to oreillys to have it tested make sure it' still work he tested it but said it' putting out low voltage 11.3v to be exact....so is it a voltage regulator or the brushes causing this and if it' the regulator what is the specific regulator I need to order to get this thing back running?
Old May 7, 2018 | 07:38 AM
wssix99's Avatar
Save the manuals!
You can search the web for Alternatorman. He has a lookup for parts for just about every alternator.
