Sponsored by: CARiD
Some A/C help please
Old May 12, 2018 | 12:09 PM
01CamaroSSTx's Avatar
Originally Posted by LS1121
yes you are right. I'm looking at a New Four Seasons compressor, way cheaper than GM.
Take a look at Rockauto.com and see what they can do on a compressor and dryer. They offer Delphi OEM and it may take a week to get the parts but if you can wait on them it might be worth it to you.
Old May 12, 2018 | 07:15 PM
LS1121's Avatar
wellllllll..I just had the trans rebuilt, rear main seal and plate replaced and had a new oil pan gasket installed so my funds for this car are a little crimped right now. I'm going to look for someone to rebuild my compressor locally if I can.
Old May 12, 2018 | 07:39 PM
merim123's Avatar
Before you spend any money chasing parts, stop. you need to pull a vacuum now and see if the system is sealed or not. The fact you needed some every year says the system is not sealed.
Old May 13, 2018 | 09:13 AM
LS1121's Avatar
Yes, I put the yellow dye into the system and could not find a leak anywhere. I'm thinking it's coming from the compressor in an area I cannot see without removing it. I'm looking for an adapter to screw onto the top of the small cans of Freon and onto the 1/4" hoses and gauge set I use for my house. It is definitely leaking but from where is the question.
Old May 13, 2018 | 10:10 AM
Yeah I'd check all the usual places and replace all the o-ring/seals seals for the lines at the compressor, drier, condenser, etc. then pull a vacuum on the system and see if it holds or it leaks down. If it holds your good to go with a recharge that is of course if the pressure/transducer switch is working properly and your compressor is good.
Old May 30, 2018 | 07:10 PM
LS1121's Avatar
So, Yes, when I got the compressor off I could see where it was leaking from. I vacuumed the system and installed the new parts and it is very cold now. Thanx. Now I want to rebuild my old compressor. I bought a gasket seal kit for the V7 compressor, all I need now is to get a clutch and magnet. Are there any good aftermarket parts for this or do you think I need GM parts?
Old May 31, 2018 | 05:10 PM
Glad to hear its blowing cold again. Rockauto.com will have all the parts to rebuild your old compressor.
