ls1 oil leak
The gasket is riveted to the pan, making it pretty difficult to remove with the pan in place. A common leak point is where the oil pan gasket meets the rear or front covers. The factory service manual instructs you to apply a small bead of RTV to the corners of the gasket where the rear and front covers meet the oil pan gasket to prevent leaks. Make sure you do this well and hopefully that should resolve your leak. Obviously, use a new gasket. We sell an upgraded single-piece oil pan gasket that is less expensive than OEM.
In short, the oil pan does need to come out to do it correctly.
You should be able to get it out by:
- Unbolting the motor mounts
- Raise the engine a couple of inches with a hoist
- Unbolt the front k-member and lower it around 4-5 inches. You don't need to unbolt the suspension or anything.
- Slide the oil pan out from the rear
and nice to know ( NOW after i already put a GM one in ) that improved racing has a one piece oil pan gasket......highly recommended !!!!
Sorry about that, you have to be a FRRAX member. Here's a quote of what was said:
I recived the baffle a few weeks ago. First impressions: nice brushed aluminium, clean, precise welds. I had an old LS1 pan sitting around. Test fit: perfect. Lines up nicely, bolt holes all line up on center.
I opted to install it with out pulling the motor. Went fairly quick and easy. I got the car on jackstands. Attached a cherry picker to the front of the engine. moved the aternator out of the way. Removed the long motor mount bolts. Lifted the engine about 2 inches. Disconnected the intermediate steering shaft. I have an alternate brake line routing, so I did not have to loosen the ABS module. Disconnected the oil level sensor. Slowly removed the 6 bolts holding the k-member to the body. The K-member dropped about 4-5 inches down. Keep in mind I still have the swaybar, ect attached.
Next I pulled the oil pan bolts and took the pan out. I pulled the OEM baffle from the pan, dropped the Improved Racing Baffle in, and instaled on the car. The rest is the reverse of the dissasembely.
Total time invested just over 3 hours. I didn't even remove the wheels. Tools needed are the ussual suspects: #10,#13,#15,#18 socket wrench, jack, jack stand, cherry picker/hoist.
So that was my Thursday night.
Friday I headed to the track. Willow Springs. For those that are not familiar with Willow, there is a 450' radius 200 degree turn. Long sweeper that just takes forever to get thru, and is a good test for any baffle.
I filled the pan to the top of the full line. About 1.5 quarts below where I ussually fill it. Sat my brother-in-law next to me with the sole responsibility of monitoring the oil pressure. Took the car out to multipe 20 min sessions. The baffle passed the test. The oil pressure held steady the whole weekend. Not even flinching in the turns.
Used the 10 ton jacks (only way to go, 5" flat saddle, dont use curved top Chinese junk) . Interesting that the front frame rails are near the CG. When put on jacks, rear end came up and car is level but still on rear ramps. Now its safe to remove the oil pan.
