Sponsored by: CARiD
Low beams inop
Old Jun 27, 2018 | 10:22 PM
Utinator's Avatar
Question Low beams inop
I have a 2000 Camaro SS. This morning, everything worked fine. Tonight, the low beam headlights would not come on. Every other light in the car came on (except the CEL). I had to drive home with the high beams. There were a lot of unhappy motorist on the roads, to say the least.
I tried rotating the headlight **** back and forth to "override" the auto light switch. That didn't work. I was able to get the high beams to work by wiggling the blinker/wiper switch , so I'm thinking there's something going on in the steering column. I tapped and wiggled every wire/harness going to the headlights that I could. Nothing would make the low beams come on. I still only have high beams.
I didn't see any fuses for headlights anywhere. Is there anything else I can check? Has anyone had this problem before?
Old Jun 28, 2018 | 07:22 AM
johnfin's Avatar
Default beams
i have had this happen. i replaced the headlight connectors and cheked the grounds. all is good now
Old Jun 28, 2018 | 03:34 PM
Utinator's Avatar
Thanks. I'll take a look at that.
Old Jun 28, 2018 | 07:02 PM
Utinator's Avatar
I got it! I took the connectors off the back side of the headlights, scraped the pins with a flat-tip screw driver, and re-connected them. Now all my lights work. Thanks for the tips!
Old Jun 28, 2018 | 07:28 PM
johnfin's Avatar
That method works for a while ( i tried it). Eventually you will need the new connectors. All parts stores and ebay carries them, cheap.
