Sponsored by: CARiD
Water Temp Fluctuation
Old Jul 22, 2018 | 03:18 PM
dlee's Avatar
Unhappy Water Temp Fluctuation
Hi, i have a 2001 B4C Camaro with 128,000 miles & the water temp will move over to 260 a few minutes after starting. I started it today & turned the ac on, went back in the house for gatorade, got in the car & in less than one mile the temp was pegged at 260. Cut the ac off, window down, turned around & back to the house, heading back the temp dropped to a little over 210 & moved back toward 260 & then back close to 210. Cut it off & i could hear the fan running, it did the same more or less a couple weeks ago when i drove it to work (4 miles), and when i cut the ac off temp dropped back to 210, today was first time i attempted to drive it since then. Anyone experience this fluctuation & any ideas as to what is causing this issue.
Thanks in advance for any & all help
Old Jul 22, 2018 | 07:57 PM
B52bombardier1's Avatar
How old is your thermostat? Ditto for the water pump??
Rick
Old Jul 22, 2018 | 08:15 PM
Utinator's Avatar
Mine is currently doing something similar. It's not going to 260 though. It's topping out around 212, and going back down. My heater doesn't work when it does this though.
Old Jul 23, 2018 | 05:47 PM
dlee's Avatar
Hi B52, i've got to go thru the maintenance info from previous owner, i think the thermostat was replaced in the last 3-4 yrs., don't remember if water pump was changed. This temp fluctuation just started after i went over to a local cow pasture 1/8 mile strip & made 4-5 passes. Couple days later the first time temp jumped & then a Code P0446 Evap. Emission Sytem came up, wondering if this code would have any effect on cooling system?
Old Jul 23, 2018 | 07:36 PM
dlee's Avatar
Checked maintenance log, water pump-thermostat & housing replaced at 115,000 miles in October 2012 along with 2 gals Dex-Cool.
Old Jul 24, 2018 | 06:19 AM
Could still be a bad thermostat or a water pump.
Rick
Old Jul 24, 2018 | 06:26 AM
Floorman279's Avatar
Stupid question, h A ve u confirmed that it actually is getting that hot? Do u have a scanner for live data? Only asking cause your first post said a few minutes after starting which it shouldn't get hot a few minutes after starting
Old Jul 24, 2018 | 07:51 AM
01ssreda4's Avatar
Air pocket in the cylinder head will give a false high reading.
Old Jul 25, 2018 | 08:14 PM
dlee's Avatar
Don't have a scanner; checked water yesterday & added approx. 1/2 gal., started car & ac on, temp up to 210 in a couple mins., drove around in subdivision & within 1/2 mile temp up to 260, cut ac off & back to house, cut it off & raised hood, both fans running, no water leaks visible, water hose on drivers side had small bubbles coming out around the hose, checked clamp & it was tight. Waited 10-15 mins & started car up, temp was slightly above 210 & started moving back up after 4-5 mins running. Tomorrow i'm going to remove radiator cap & start car to see if coolant is moving.
Old Jul 26, 2018 | 06:25 PM
LS6427's Avatar
Put a new coolant temp sensor in...and end this.
Old Jul 28, 2018 | 08:11 AM
dlee's Avatar
Thanks, will pick one up today.
