Sponsored by: CARiD
grounds
Old Aug 12, 2018 | 07:12 PM
Karl101's Avatar
Default grounds
Where are all of the grounds located on a 2000 Trans Am? I got an issue with my battery dying if I leave my car sitting longer than 1 day. Battery is only 1 or 2 years old. I cleaned off the terminals not that long ago, but I can always check again.
Old Aug 12, 2018 | 07:25 PM
WhiteBird00's Avatar
Ungrounded Moderator
Well, aside from the fact that a bad ground will never cause a battery drain, there is a thread here that lists them: https://ls1tech.com/forums/pontiac-f...-all-them.html.
The best way to locate a parasitic drain is to put an ammeter between the battery terminal and cable (either positive or negative will work since a complete circuit is necessary for current to flow) and first check if there is more than 80 milliamps of flow then start pulling fuses until you find the one that eliminates the draw.
Old Aug 13, 2018 | 12:27 AM
Karl101's Avatar
thank you. figured I had to start somewhere and I didn't know that lol
