4th Gen Camaro chassis dimensions.
I'm looking to see if anyone has any drawings showing dimensions for the chassis and location of the driveline. I have done a fresh install of an LS3/TH400 in my 98Z with a BMR K-member. I believe my engine/trans is in crooked with the tail of the trans pointing towards the passenger side (header collector almost on the floor pan). I have found one dimension showing the engine center at 14-3/8" off the passenger side frame rail. By dropping some points I'm about 3/16" more towards the drivers side frame rail which is about how much the transmission mount is off. So before I loosen everything up and move stuff around I would like to see if there was any drawings out there I could reference. Thanks for any help
