Sponsored by: CARiD
Small oil leak?
Old Jan 29, 2019 | 06:46 PM
Mike1711's Avatar
Default Small oil leak?
Hi I recently noticed a small oil puddle on the floor on my 98 Pontiac firebird. I got it checked out and the mechanic said that it is the oil pan. He also said the bolts were a little loose so he had tightened it. My question is if it is the oil pan leak can’t the bolts be replaced so the leak stops? If that is not possible then how much would it charge for a oil pan replacement? What’s included in the oil plan replacement?
Old Jan 29, 2019 | 09:14 PM
bammax's Avatar
The bolts don't leak and you don't need a new pan. Tightening the bolts may have fixed it. If not you need a gasket. In any case you should just let a mechanic handle it.
