Sponsored by: CARiD
Camaro cold start issues
Old Mar 10, 2019 | 07:53 PM
TransAmWS.6's Avatar
Default Camaro cold start issues
Hey guys, have been experiencing some odd behavior on cold starts with my 2002 Camaro SS for a while and finally getting around to asking about it. I will start off by saying that the car is a garage queen and will sit for several weeks at a time. Basically what happens is I will go to take it out for a cruise and the car will initially fire right up and idle normally, but when I put it in D, it will stall out. Most of the time it starts right back up on the first try, but there has been times like today where it cranks and cranks and cranks and I have to do 2-3 cycles with the key for it to turn back over.
Any ideas as to what this could be? I replaced the battery not long ago and the voltage reads within the normal range. I was thinking it could be tune related, but it actually did this before I had all the mods/tuning done. Car runs strong and will start up every time after it is driven for a little bit and warms up. Not sure, any advice is appreciated!
Old Mar 10, 2019 | 08:46 PM
LLLosingit's Avatar
I would start by checking fuel pressure, There are other things it could be but a failing fuel pump can cause the issues you described.
Old Mar 10, 2019 | 09:48 PM
I thought about that as well. But it doesn't make any whining noise or anything and the car has low mileage (32k) so I thought maybe not, but I will look at the pressure. I guess anything is on the table at this point.
Old Mar 11, 2019 | 07:27 AM
wssix99's Avatar
Save the manuals!
Maybe your torque converter is going. I'd first try starting the car in N when you have this problem again and see if it cures the issue. If so, the torque converter may be putting extra drag on the crank.
Old Mar 11, 2019 | 01:24 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
When I read this part:
...my very first thought was the same as LLLosingit - fuel pressure and/or pump check valve issues. But then I read the following:
If the pump is bad enough to cause stalling at cold idle then I would expect it to likely exhibit some issues under load and/or when warm as well. The check valve could still be failing even if operating pressure is strong (causing the hard restarts/need for several key cycles), but that wouldn't explain the stalling issue....unless there's a second problem which is not related to the pump. I wonder if there is an MAF related issue here?
Have you checked for stored/pending codes (even if no SES is present)?
Have you checked fuel trims?
Checking fuel pressure is still a good idea based on the symptoms, if nothing else just to rule it out. You'll want to check it under load as well, plus leave the gauge connected for a while after engine shut down to see if it holds pressure (and how much) for a period of time.
If fuel supply is weak, it could certainly cause the stalling and hard restarts, but a flooded engine can also behave in a similar way. When you experience one of those hard restarts, have you ever tried holding the throttle wide open (clear flood mode) during cranking?
Old Mar 11, 2019 | 10:10 PM
I will try this next time. I really hope it is not the converter, locks up perfectly and hits hard. It probably has less than 2k miles on it.
Have not checked for codes since I never got a SES light, but I will do that and take a look at the fuel pressure. I forgot to mention, I have also had situations where I have actually started driving the car and then it will randomly stall and the gauge cluster lights up. Luckily, I have never been in traffic when this has happened. This stuff always occurs within the first 5-10 minutes of it running after it sits for a while. It typically will start right back up and drives perfect without issue for the rest of the time afterwards.
I actually did some running around in it today and it was fine I guess I will check fuel pressure and scan it for codes and report back.
Old Mar 27, 2019 | 07:56 PM
Hey guys, just wanted to update this. I am waiting to start a new job and have some time off so I've been messing with the car. I haven't had a chance to check for fuel pressure but did check for codes and nothing came up. However, the strange thing is that the car has not been acting up. I drove it 3 days in a row and it didn't hiccup whatsoever. I'm not sure, maybe this is related to it sitting for long periods of time without a battery tender. No idea, guess I'll revisit this if it occurs again or gets worse. Anyways just wanted to update, thanks for all the help!
Old Mar 28, 2019 | 08:05 AM
wssix99's Avatar
Save the manuals!
Are you having warm weather? Maybe the EGR is in play, here?
Old Mar 28, 2019 | 02:36 PM
RPM WS6's Avatar
Not on an '02 car like TransAmWS.6's.
Based on the update, it's possible that somewhat low battery voltage on a cold start might cause the isolated idle weirdness that the OP is describing; PCM memory for learned parameters might become incomplete or corrupt if voltage was low enough during cranking, etc. I've occasionally seen a similar low idle condition (only in gear) on my '98 after sitting for long periods, especially if battery voltage had gotten a bit weak while sitting. Just like the OP mentioned, mine has always cleared up with a simple restart, only difference is I haven't experienced any sort of stalling or the long cranking periods/difficulty restarting associated with the occurrence of this low idle. So there still might be a separate, also intermittent issue that's causing those other conditions for the OP.
Old Mar 29, 2019 | 07:03 AM
wssix99's Avatar
Save the manuals!
Thanks, I'm numb to these modern cars.
I'll go back to the '90's now...
Old Mar 30, 2019 | 09:07 PM
RPM and wssix99 I appreciate you guys. Another small update. I ended up taking it to the drag strip last night, car actually stalled on me after I did a burnout. Its like the sudden drop in RPM's after doing a burnout was too much and it killed it, did this twice actually. Car did the same thing as I described before, hard slow start and idled low for a couple seconds, then everything was back to normal. I am actually starting to think this could be tune related. Does that sound like a reasonable guess at this point? Only thing that makes me second guess is that the car runs so strong. No cutting out or breaking up like its hurting for fuel or anything.
Old Mar 31, 2019 | 12:59 AM
RPM WS6's Avatar
Aftermarket tuning is often suspect in cases like this, especially because some aftermarket tuners don't spend extensive time on broad-scope driveability tuning, but you mentioned this condition predates the modifications and tune - so that's not likely at the root of this problem (though a less-than-precise tune might be aggravating some aspect(s) of this condition).
Wonder if the IAC is part of the problem? This certainly wouldn't be my first guess for a problem like hard starting/long cranking periods alone, but it could certainly be a factor in the other aspects of this condition.
Old Mar 31, 2019 | 05:42 AM
TTur1996's Avatar
First check your chassis grounds, and all grounds for that matter. If that don't do it, do a smoke test on the intake. Sounds like you could have a periodic vacuum leak. (something loose) Retorque all on the intake and throttle body. Smoke test will tell you. Unless its a plastic intake and its internal.
