Serpentine Belt
Current belt that doesn't match the grooves keeps moving out to this position.
"if your pulleys have been changed to aftermarket ones...its a crap shoot for us to guess. If people put on "underdrive" pulleys than typically a shorter belt 1/2" to 1" is needed. Belt lengths are the last three #'s of the belt # and can be ordered per # vs application.
If you do have underdrive pully and it says what brand it is typically 411 about that pully if you google it will come up and say what belt to use
ATI underdrive balancer pully, for example, show what belt # to use with their pully
You say the belt on there does not fit the grooves. Is it migrating out of the grooves? If it is then the belt tensioner may have been slightly bent. I did that once. I used a breaker bar on the belt tensioner to release the tension and used a little too much force and tweaked the tensioner and had to replace it because the belt kept moving out of the grooves. Try a stock serpentine belt, be sure to follow the correct routing diagram. People do weird **** sometimes. Previous owner might have it routed wrong, used a non-standard belt or who knows what.
Try the stock serpentine belt, route it properly. If it doesn't fit you will need to start measuring pulleys, etc. to find out what you have.
