Sponsored by: CARiD
Aftermarket AC Condensor Brands
Old Jul 29, 2019 | 11:50 AM
j498's Avatar
Cool Aftermarket AC Condensor Brands
2000 T/A LS1 M6
Redoing my AC system as my compressor works but has been leaking oil/refrigerant and has started to make noise. I'm probably going to replace the condenser to be safe but I dont see a lot of feedback on the aftermarket replacements. Are these decent replacements compared to OEM?
I'm looking at the following brands on rockauto
UAC CN3004PFC
APDI/PRO 7013004
OSC 3004
Does anyone have experience with these brands? Any feedback?
Old Aug 12, 2019 | 12:12 AM
j498's Avatar
Update: Being unfamiliar with these brands, I went with a spectra premium condenser - 73004. Though be-forewarned, if you get this unit its missing hardware for attaching the lower hose coming off the AC compressor. The factory condenser has stud screwed into the condenser with a nut holding the hose on. The spectra just has a drilled and tapped hole with no stud or nut. So you're need to get your own or substitute a bolt instead. I was able to substitute an M8-1.25 x 30 (or 35MM) flanged bolt for the lower hose. Also, regarding this unit, if you try to torque the lower host to spec, it will being bending the tube that protrudes out from the condenser, where the hose attaches. So be careful.
Old Aug 12, 2019 | 06:37 AM
klinznilk's Avatar
You can avoid issues like stated above if you use the F/S (four seasons one) part number: 40004
https://www.4s.com/en/ecatalog?part=...ype=p&search=s
Old Aug 16, 2019 | 06:13 PM
j498's Avatar
For me, I looked for a four seasons prior to ordering and none of the places who could get it to me had it in stock
Side note, here's what happens when you try torquing the lower hose to spec on the spectra condenser. (pic taken in a mirror)
