Sponsored by: CARiD
Instrument cluster not working?
Old Feb 14, 2020 | 07:51 PM
Gacarrizales's Avatar
Default Instrument cluster not working?
I have a 2000 Trans am (convertible) & the instrument cluster isn’t working. I was driving when suddenly all my gauges went to 0. The only one working is the oil gauge. I tried to replace the fuse & it just instantly got blown out. Has anyone had this problem? How did you solve it? I’ve read it could be a couple of things. Not sure which to believe. My driver side low beam light isn’t working either, right after I had replaced a gear in that motor too.
Old Feb 15, 2020 | 08:03 AM
wssix99's Avatar
Save the manuals!
The fuse being blown is the reason the gauges are shorting. You would need to look at everything on that circuit and trace the components for shorts to find the issue, or remove the components of the circuit one-by-one until the problem goes away. If you register on AutoZone.com and go to their repair section, you can see all the schematics.
This is a common problem caused by corrosion on the motor connector pins. When you disconnect the motor and then re-connect it, the pins make new contact over corrosion and electricity doesn't flow. The best solution is to take the motor out and get some emory cloth, tear off thin strips, and then use small tools/dentist tools, to sand all that corrosion down. Using dialectic grease on the pins may help to keep the corrosion from coming back.
