Sponsored by: CARiD
Hard starts after LS3 is driven.
Old May 14, 2020 | 02:00 PM
383z's Avatar
Default Hard starts after LS3 is driven.
I'm having trouble starting my Trans Am after the engine is at normal operating temps and I'm looking for a solution to fix this problem.
The car starts right up when it's a cold start. After the car has been ran, it turns over for about for 3-7 secounds before it starts.
A little about my 2000 Trans Am:
-Compression is about 10.43:1
-LS3 -Trick Flow heads and their cam
-92mm NW throttle body
-Supposedly tuned by Pat G and I seen a video of it been tuned at his shop. (I bought the car with all the modifications)
Any suggestions on the solution?
-Look at the tune again?
-Better/stronger starter with more torque?
Old May 14, 2020 | 05:13 PM
bammax's Avatar
My first thought is the starter solenoid getting cooked. Do you have headers that sit close to the solenoid?
Old May 14, 2020 | 07:15 PM
68Formula's Avatar
Had this problem since you bought it, or just started (no pun intended) recently?
Old May 15, 2020 | 12:25 PM
383z's Avatar
I have 1-7/8 Speed Engineering long tube headers on it. You're right. That could be the problem. I might have to wrap the starter.
It's been doing it since I bought it.
Old May 24, 2020 | 05:57 PM
383z's Avatar
Anybody have any other suggestions?
Old May 24, 2020 | 07:59 PM
68Formula's Avatar
What exactly is it doing? Does it struggle to crank the engine (high load on the starter)? Or does it crank easily, just doesn't catch? Is it running the factory fuel rails and fuel lines?
Old May 25, 2020 | 08:26 AM
bigbomber5's Avatar
I've developed this issue as well. To add on what has already been mentioned from what I found it could also be your battery. It puts more stress on the battery to start up a warm car rather than a cold start up, so if the battery is going bad that could be the culprit. Another thing it could be is the fuel pump. Same as the battery it's harder on the fuel pump to start a warm car rather than a cold one. Could be a sign the fuel pump is beginning to go.
Hope these other suggestions help you out
Old May 25, 2020 | 08:37 AM
chevymec's Avatar
Does it turn over at the same speed when hot? You say it turns over for 3-7 seconds before it starts, have you checked your fuel pressure to see what is happening?
Old May 30, 2020 | 06:32 PM
383z's Avatar
It seem to crank easy to me, but doesn't start. It has factory LS3 fuel rails and stock lines.
Old May 30, 2020 | 06:38 PM
383z's Avatar
The battery is 2 yrs old and it "shouldn't be" the problem. I'll check it out with another battery.
Fuel pump...man....that doesn't sound fun. I'm not the type to cut my car up either.
Thanks for the tips.👍🏼
Old May 30, 2020 | 06:40 PM
383z's Avatar
To me it sounds like it's turning the same speed as if it's cold. I'll try and listen to it better today.
I'm going to have to check the fuel pressure now that everyone is pointing it out, because I haven't.
Old May 30, 2020 | 07:32 PM
68Formula's Avatar
If it's cranking easily, then doesn't sound like a battery or starter solenoid issue. Maybe something was changed after it was initially calibrated, and it needs a recal. Or maybe you have vapor lock.
Old Jun 2, 2020 | 10:44 AM
TA_Freak's Avatar
Check your fuel pressure ... and check for any vacuum leaks. I had a hard start issue on my LS1 several months ago and it turned out to be some old vacuum lines from the PCV system. It was harder to start after it was warmed up ... and it also stumbled a bit when it did start.... from the vacuum leak.
Old Jul 4, 2020 | 10:15 PM
383z's Avatar
Ok, I THINK I need a new fuel pump.
When I turn the key to ON (not crank the engine) the fuel pressure sometimes goes up to 58psi.
Sometimes it stumbles around 20ish up to 55ish. That when the car stubbles to start.
Then while driving the fuel pressure starts dropping from 58psi.
3,500rpm to50psi
5,700rpm to 40psi.
Any recommendations? LS3, TF heads, TF cam, SE LT and duel exhaust, 92mm NW throttle body.
Old Jul 7, 2020 | 10:12 AM
TA_Freak's Avatar
Have you replaced the fuel filter first? A clogged filter will obviously effect the fuel pressure.
Old Jul 13, 2020 | 12:12 AM
383z's Avatar
Nope, But since it easy and cheap I can do it first.
