Sponsored by: CARiD
HELP Stripped Starter Bolt Hole !!!!!
Old May 20, 2020 | 09:49 PM
corvet786c's Avatar
Default HELP Stripped Starter Bolt Hole !!!!!
Its the one on the inside where the header is not blocking, Does the header have to come off? Seems like I would need a longer type of Tap, Any advice anyone have a fix thanks
Old May 21, 2020 | 10:03 AM
rising_4rm_ashes's Avatar
I never really had to fix that thread; however, you are going to need to space to insert a heli coil in there.
Old May 21, 2020 | 03:06 PM
corvet786c's Avatar
Yeah Thats what I am preparing to do, I made a long extension hopefully it will go in straight.
Old May 21, 2020 | 06:51 PM
corvet786c's Avatar
any other advice about performing this Thanks
Old Jun 3, 2020 | 12:32 AM
13.7ls1's Avatar
I have not seen longer taps. All my taps (and I have lots of them - from what I bought and some my dad gave me) I have seem to be around maybe 5" in length. It sounds like maybe if you could get a starter tap (where first part of tap does very little cutting) - that might work.
Id be interested to see if there are longer taps...and then how you would hold and cut/repair the threads.
Old Jun 3, 2020 | 12:45 AM
Twin_Turbo's Avatar
Time sert
Old Jun 3, 2020 | 08:13 AM
01FormulaTA's Avatar
I cross threaded one of these bolts before when I was in a hurry, I just used an M10x1.5 tap, then sprayed the hole down with some WD40 and compressed air, and then torqued the bolts to the 37 lb-ft
Old Jun 3, 2020 | 01:10 PM
wssix99's Avatar
Save the manuals!
Originally Posted by Twin_Turbo
Time sert
Time Sert does sell a specific kit for this on the GM Aluminum Block engines; sold through Amazon:
Amazon Amazon
^ You should just confirm the bolt size.
Before you have a heart attack on the price; I had a similar problem with a stripped O2 Sensor bung and had to spring for Heli-Coil's specialized kit for those threads. The parts were expensive, but the time it saved in the end was immeasurable.
