Rear Main Seal install
The alignment tool aligns the cover perfectly around the crankshaft. With the seal already installed, you have to eyeball the centralization and be careful how you tighten the bolts. In the end, you probably won't get the longevity out of the cover+seal that you would by doing them separate with the special tools - but that may not be an issue. Obviously, lot's of people are skipping the cover alignment and the world isn't coming to an end. (Over cover alignment, anyway.)
Being that the rear main cover rarely wares out, we recommend just buying the FelPro seal and gasket kit. Yes the AlignIt tool is a little pricey but it is a precision CNC machined piece.
Our Rear main tool is around $50 but is doesn't ware out so it is reusable. Just so you know, the GM service manual says to align the cover using the Kent Moore tool that cost around $500.
That's why we designed our patented inexpensive tool that is more accurate and easier to use. If you don't get the cover perfectly aligned the seal will rub harder on one side and cause premature failure.
When you think of what it takes to go back in and do the job again, $50 is a small price to pay. Anyway just wanted to let you know the importance of doing it right the first time and that its worth using a tool and not eye balling it.
www.saccitycorvette.com/AlignItTools.html
Thank you,
Christian
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
Now that I've said that, it looks like my new hydraulics are leaking and I'm going to have to drop it again.
We recommend reusing your original rear main cover since they rarely wear out and get a Fel Pro seal and gasket kit. If you are going to use a new cover
that comes with the seal installed and you want to get the cover aligned properly, then you will have to use a Kent Moore tool ($400). Or you can remove the seal if you want to use our alignIt tool.($50)
Thanks
Christian
Thank you for your business and using our AlignIt tool.
When you say "my new hydraulics are leaking" are you talking about the clutch Slave cylinder?
Thanks
Christian
Christian
If you need the AlignIt Tools or our Billet oil System improvement parts we have them ready to ship.
https://www.saccitycorvette.com/AlignItTools.html
https://www.saccitycorvette.com/OilS...provement.html
Thank you,
Christian
