Sponsored by: CARiD
Yes, a window motor thread
Old Jun 9, 2020 | 08:22 AM
wssix99's Avatar
Save the manuals!
Originally Posted by ARSENAL670
The brass headlight gear swap being a similar undertaking.
Read deep into this one... The brass gears don't cure the grinding, the OEM motors are not very good, and the motors also come apart from the gearbox, which can't be cured. If you are having problems, your best bet may be to change the entire motor. (BTW - the new Cardone motors also have doors to service the gears in the future.)
Old Jun 11, 2020 | 06:30 AM
ARSENAL670's Avatar
I have zero issues right now, but I figured might as well do some preventative upgrading. If that is the case with the headlights, I might as well do the motors and the gears all at once.
Also - the Cardone window motors off of Amazon - are they safe to buy, or is there a chance they could be counterfeit? I know Amazon has issues with counterfeit goods that are ripping off of OEM parts, but haven't heard of OEM replacement parts being counterfeited.
Old Jun 11, 2020 | 06:49 AM
formula218's Avatar
Just did the Autotrix fixes with new OEM motors using the SHBOXX method and it wasn't bad at all. took about an hour total per door. Motors are pretty cheap from the dealership, and I don't think i've ever had good luck with anything Dorman.
Old Jun 12, 2020 | 08:06 AM
RevGTO's Avatar
Pontiacerator
I have zero issues right now, but I figured might as well do some preventative upgrading. If that is the case with the headlights, I might as well do the motors and the gears all at once. Also - the Cardone window motors off of Amazon - are they safe to buy, or is there a chance they could be counterfeit? I know Amazon has issues with counterfeit goods that are ripping off of OEM parts, but haven't heard of OEM replacement parts being counterfeited.
I've heard about that with Amazon. You could use Rock Auto which will deliver the authentic goods.
I wouldn't replace the headlight gears preventatively. Those motors may go a long long time before going bad. "If it ain't broke, don't fix it." Also, we've had 7 or 8 4th gen Firebirds in our family, and I've never had to replace a passenger side motor, although doing 4 or 5 driver's side.
Old Jun 13, 2020 | 07:39 AM
wssix99's Avatar
Save the manuals!
^ Good advice. The motor connectors also corrode and each time they are unhooked, the higher the chances of a related electrical problem. (So, another reason to not touch them until needed.)
I stick to buying parts from parts dealers. Amazon is not a retailer or dealer for everything. For many products, they are just a marketplace. (like eBay)
Old Jun 13, 2020 | 05:54 PM
chrysler kid's Avatar
I think the window motors are like $19 or $29 at autozone with a lifetime warranty
I can usually get 5 years out of the dorman motor
My passengers side is original with an autotrixx window kit
There was another vendor making motors on Amazon and eBay. They were advertised as faster and stronger but I only got 2 years of choppy window service. They were faster but the motor or the gear would slip on the regulator. Don't remember the brand but they were polished aluminum in appearance
Go to AutoZone and get the lifetime warranty
Old Jun 15, 2020 | 06:27 AM
ARSENAL670's Avatar
I'll stick to that advice. Thanks. For now, i'll just upgrade the lighting as I had planned. Almost done with the full LED exterior swap; barely completed an LED fog light bulb swap, but i'm not overly excited about it, and may seek out a 4 1/2 replacement LED pair of actual lights.
Old Jun 15, 2020 | 10:45 PM
wssix99's Avatar
Save the manuals!
Are you watching out for the cruise control implications?
Old Jun 16, 2020 | 06:11 AM
ARSENAL670's Avatar
I remember reading about that. I do have a digital flasher (only one), and my hazards do not currently work, because I need to change out the other. As far as the cruise control, I never use it. Ever. My daily driver is a 2014 Grand Cherokee with a tuned Hemi, and pre-COVID19, I was driving 43mi in one direction to work 5 days a week. Never used cruise control in that either. So for me, the feature is not a major concern.
Old Jun 16, 2020 | 07:23 AM
wssix99's Avatar
Save the manuals!
Unless you sell it. I recall the cruise controls require a full electrical load on the brake lights to work. You should be able to add special resistors to those lamps to keep the function if you go LED. (There are some threads on the site with the specifics.)
Old Jun 16, 2020 | 12:30 PM
ARSENAL670's Avatar
Unless you sell it.
....which I will never do. Had this car as the second owner for the last 15 years - it's not going anywhere. Unless of course, someone in the family, God forbid, needs a kidney, a heart transplant or some other catastrophe happens. I was in college when I started searching for my 86 WS6's replacement that I had since high school. Took 3 years, but i've had it since.
Old Jun 16, 2020 | 09:39 PM
  #32
wssix99's Avatar
Save the manuals!
^ Then you are old, like me. Every day that goes by, you need that cruise control more and more and more.... The pedals never get lighter - only heavier.
Old Jun 17, 2020 | 06:03 AM
  #33
ARSENAL670's Avatar
Just beginning my 40's....still got some time in me before osteoporosis and arthritis starts taking things over For now, the pedals are light and the foot is heavy. I know it will change, but I'll fight that tooth and nail until I'm driving a Caddy. (with a supercharged LS in it, of course).
Old Jun 18, 2020 | 08:30 AM
  #34
wssix99's Avatar
Save the manuals!
You are closer to that Cadillac than you think. But you'll get to a point in the interim, where you'll want that cruise control.
BTW - I got my first bouts with arthritis in my 30's. It can come at any time!
Old Jun 18, 2020 | 08:40 AM
  #35
ARSENAL670's Avatar
As long as it's the latest CTS-V, i'll take it. Maybe at some point, it will come in handy, but for now, I just want to enjoy it. I read that thread a long time ago - the fix is the secondary flasher (which is why my hazards do not work currently), correct?
Not good to get arthritis....i've been fortunate thus far to have staved off any major illnesses or health issues that impact anything related to mobility or otherwise.
Old Jun 18, 2020 | 03:23 PM
  #36
wssix99's Avatar
Save the manuals!
LED's, installed in a stock car, generally will not flash and will cause the cruise control to malfunction.
The electronic flashers will cure the former issue but not the later. I recall that loads need to be added to the brake lights in order for the cruise control to be happy.
Old Jun 18, 2020 | 07:43 PM
  #37
wannafbody's Avatar
I don't think the plastic headlight gears are all that bad. I replaced the drivers side motor at 10 years and the passenger side is still original at 20 years.
Old Jun 19, 2020 | 12:24 AM
  #38
RevGTO's Avatar
Pontiacerator
No arthritis here, but I'm in my 60's and after a medium length freeway drive, the muscles in my right foot and ankle start to bind up. I drive Wichita/San Diego pretty much every year, and without CC, it ain't happenin'. If you're never going to sell the car, it might be worth keeping.
Old Jun 19, 2020 | 06:22 AM
  #39
ARSENAL670's Avatar
Good to know. I'll revisit that thread after i've completed the majority of the other upgrades.
That's a hell of a drive. Zero plans in selling the car (really, only if there is some unforeseen emergency), but at some point I will be coming back to this.
