Running Warm with A/C on, HIGHWAY
Fellow members, I need some help diagnosing an issue that is REALLY bugging me and hurting the value of my car that I hold internally. So, my A/C blows cold and hard out of all vents, during all times of the day. The issue that I am having is when I'm cruising in 6th gear say 60+ MPH, during the day, my car starts to run hot, based on the temp gauge C/T the gauge cluster. Now, when I turn the A/C off (Not wanting to ruin my engine and components of course) , the car gradually cools down to mid-temp on the gauge. I've been trying to solve this riddle for a while now, as I've just had a Magnum-F installed and am trying to get her broke in by daily driving, and during my 15 minute, 18 mile, highway blast at 80 MPH, I cannot remain hydrated do to all of the perspiration. I live at the SC/ GA state line, and here, hot is the unit of measure that typically describes the spring, or fall seasons. Summer is just stupid, that's how hot it gets.
Things to note. I have a BTR Stage 4 installed with an aggressive lobe. When the air conditioning kicks on, my voltage drops below the mid-range. The longer the run time, the lower it gets, even at highway speeds. However, If I flick my lights on, the voltage rises and goes to the mid-range and sits there, but won't keep the car from running hot.
Looking the car over, the previous owner installed a volant CAI and lost a bracket I suppose, as the condenser and the radiator are separated by at least 1.5 inches. Also, my air dam is no longer with us at the moment. The fans kick on at idle so they are working. I don't see any persistent leaks around the water pump, and I've just topped the radiator off again. I'm stumped honestly, but before I just go ahead and replace the water pump, thermostat, and radiator hoses, do you all have any suggestions?
When idling or city stop and go your electric fans are keeping the engine coolant cool......air dam doesn't do a whole lot.
Put the air dam back on and your overheating issue will be gone.
Also, just to check the fans out........check to see if your fans (both at the same time) work on low and high settings........and check to see that the fans come on when you turn the A/C to MAX after you are at full operating temp.
When idling or city stop and go your electric fans are keeping the engine cool......air dam doesn't do a whole lot.
I wasn't sure how much of a difference having the dam on would make, but logically speaking, it could make all the difference in the world. While at low speeds, the fans should be enough to suck air through the radiator and condenser, but at highway speeds, not having the dam will render the fans usless, if they even kick on.
I'm not sure when my dam went missing, but I'm gonna see if I can find one locally, install, and find out if that remedy's my cooling issue. I also need to close the gap between my radiator, condenser and front support.
There should be some at junk yards.
So I checked that over the weekend but I didn't examine close enough to see BOTH fans kick on at idle at op. temp. I really only listened for them to kick on while I was bleeding the system again. Makes perfect since though. I'm gonna test it out as soon as I can get my hands on one. Think my broken formula might still have one installed. I'll just mark it as one of the many parts I've procured from it for use on the functional T/A
I believe they are all push pins.......the dealer will have that. Or any auto parts store.
https://www.ebay.com/itm/93-02-FIREB...4AAOSwSDtenwlY
https://www.ebay.com/itm/93-02-CAMAR....c100005.m1851
It goes in front of the condenser and helps direct the ram air from the air dam backwards and through the condenser/radiator. When my new engine was installed the shop did not put that in and it was a leftover part. I figured out what it was along with running a little hot....... As soon as out it back in the engine ran normal temps.
https://www.ebay.com/itm/GM-Hex-Head...AAAOSwi~Fbmteq
