Sponsored by: CARiD
Cleaning / lubing the windows track
Old Oct 7, 2020 | 09:32 AM
wrd1972's Avatar
Default Cleaning / lubing the windows track
Okay cant put it off any longer. The original grease is sticky and has burned up another motor. What is involved in PROPERLY degreasing those track and re-lubing them. Do they need to come out of the car? Anyone have a write up on how to do it?
Thanks
Bill
Old Oct 7, 2020 | 09:47 AM
wrd1972's Avatar
BTW I am speaking to 4th gen windows.
Old Oct 8, 2020 | 10:54 AM
wssix99's Avatar
Save the manuals!
By design, the grease is very sticky and designed to hold up in a wet environment. It can accumulate dirt and dust over time and become less effective - so no harm in changing it out but we don't have a record here of that causing motor problems. (There are lots of other ways that goes down.)
The most important thing is to use a compatible silicone grease for the replacement. Sil-Glyde is what is used for the track and you can get it at any parts store:
Just take the door panel off, take the door speaker out, and then use a dry rag to wipe the grease out of the three tracks. (One attached to the window glass, one vertical at the back of the door, and one short horizontal track, hidden in the inside panel right next to the speaker.) Then generously lube the roller and track around the roller with Sil-Glyde. Actuate the window. Repeat, if necessary until everything wipes out clean grease. BTW - The "rollers" on the regulator and the tracks don't actually roll. So, don't worry if they don't seem to move freely. They just pivot on ball joints and glide in the tracks. (BTW - Also don't try to remove them. The posts they mount to are fragile and trying to manipulate them can break them or the posts/tracks. This will tail-spin you in to a new type of expensive hell because replacements are not available.)
If you put in a new motor and the movement of the glass is slow, you probably have something else weighing on the mechanism. The common problem is improper adjustment of the window stabilizers. Be sure to follow these instructions exactly and in this order and you should get a smooth moving mechanism: http://shbox.com/1/adj_window.html
