Sponsored by: CARiD
Had a problem.
Old Dec 8, 2020 | 12:54 PM
Patrick Leathers's Avatar
Default Had a problem.
I drive a 2001 Z28 Camero. Yesterday I lowered my steering column to put a new ip dimmer switch on. I removed the brace underneath and tied it up so I could get it a little lower for access to the switch. After I finished the work I put everything back together and noticed a puddle of fluid under my car. Did I damage something by lowering the colum to far. Just put a new pump in about a month ago. Frustrated, this car was a police pursuit vehicle when I bought it if that makes any difference.
Old Dec 8, 2020 | 01:23 PM
blackbeard44's Avatar
what fluid leaked out, oil? P/S fluid? coolant?
A/C will drip water off of the core and it will drip out on the passenger side, that is 100% normal.
but if you are leaking an oil, thats gonna need to be fixed
Old Dec 8, 2020 | 04:36 PM
ss1129's Avatar
Steering column doesnt directly link to anything that would leak by you dropping it. Its probably a separate issue. Also helps to see what the fluid is.
