Sponsored by: CARiD
Look what the idiot did
Old Dec 11, 2020 | 11:08 AM
VIP1's Avatar
Copy & Paste Moderator
Originally Posted by pcardinal42
You decompress the spring with the clamp that the wrench is stuck on and can only turn one way because it is racheting style in the box end. If it's was just as easy as loosen it I wouldn't have bothered making the post.
If that is the one-way kind without the switch to reverse it, then I was thinking to use an open-end wrench to loosen as far as can go (the stuck wrench will bind against the spring) and see if that gives enough room to work off the stuck wrench or at a minimum reduce the amount of prying needed. Either way, you got someone local to get it off.
Old Dec 21, 2020 | 08:47 AM
01Z0H6's Avatar
I can so see me doing that....
Old Dec 21, 2020 | 11:02 AM
SAPPER's Avatar
I'm with the pry bar guys. Too easy.
Old Dec 23, 2020 | 09:42 PM
Sacrilege's Avatar
Just cut the wrench and take your life lesson.
Old Dec 26, 2020 | 08:57 PM
br549's Avatar
Try a Roberts drive bit, that might back those screws out enough to grab them with a pair of Vise Grips.
