Sponsored by: CARiD
Can’t turn the ASR off.
Old Dec 25, 2020 | 07:13 PM
Need4Camaro's Avatar
Default Can’t turn the ASR off.
It’s stuck on. The bulb in the switch is never illuminated but when I push the ASR button nothing happens. The ASR Off light on the dash doesn’t illuminate. I know it’s on because it’s constantly being activated when I turn a corner have a moderate / hard acceleration. Any idea as to what’s wrong?
I heard that they share the same fuse as the turn signals. I went all LED’s and had to get a LED flasher with a separate ground wire. Will that interfere with the operation of the ASR?
Old Dec 30, 2020 | 03:24 PM
WhiteBird00's Avatar
Ungrounded Moderator
This is all assuming that the traction control module actually works and the problem is just with turning it on and off...
You can test the ASR / TCS switch quite easily... pull the switch out from the trim panel or remove the trim panel so that you can access the back of the ASR / TCS switch. Unplug the connector from the switch and, with the ignition on, momentarily ground the brown/white wire. That should toggle the traction control on and off. If it does then either the switch is bad or the black/white wire is not properly grounded. You can check that by using a short piece of wire as a jumper to momentarily connect the brown/white wire to the black/white wire. That would be the same thing the switch does internally. If the traction control toggles on and off then you know it's the switch. If not, it's a bad ground on the black/white wire.
