Sponsored by: CARiD
Belt squeals when AC turned on
Old May 10, 2021 | 08:57 PM
Double Aught's Avatar
Default Belt squeals when AC turned on
This is a new problem. 94 LT1 restomodded into a 68 Impala SS. AC blows cold air, but when I turn it on, at low rpm's it squeals like no other. It has never done this. I recently replaced the drive belt with an exact same model. I have a second belt, slightly smaller OAL. Would it be a good idea and swap in the other belt?
Old May 11, 2021 | 11:09 AM
chevymec's Avatar
What condition in the tensioner in? How old is the AC compressor? Any rust look on the clutch?
Old May 11, 2021 | 03:33 PM
I'll look at the compressor again, but it didn't appear to have any. Now that tensioner might be worth looking at. That might be OEM. I will go through my receipts to see if I bought one or not. Thanks.
Old May 18, 2021 | 09:35 PM
After determining it wasn't the AC compressor, I removed the tensioner pully. The bearing appeared to have some wear on it. when I turned on the AC, it exacerbated the problem. Getting a new pulley hopefully by the weekend.
