Sponsored by: CARiD
94 TA temp issues
Old May 17, 2021 | 12:28 AM
Breadboy830's Avatar
Default 94 TA temp issues
94 trans am gets hot at highway speeds instantly cools at idle. My 94 ta gets hot at highway speeds but cools at idle just got it back on the road after buying in December never overheated but gets close I believe one fan is spinning but other one doesn’t as far as I know. Wondering if someone has any ideas. Thank you for your time. Lt1 with a 4l60e
Old May 17, 2021 | 08:17 AM
wssix99's Avatar
Save the manuals!
The first thing I would check for are items restricting air flow over the radiator. Bird or squirrel plastered across the front of it, etc.
Fan problems usually come up at idle and in really hot temperatures. For normal driving, regular air flow over the radiator should keep you in good shape.
Old May 17, 2021 | 08:53 PM
B52bombardier1's Avatar
My prediction is a collapsed lower radiator hose that only happens at the higher highway RPM's. This would be secondary to a clogged radiator.
Rick
