Brake & ABS indicators
I've found used modules on eBay of questionable quality, haven't found any new aftermarket modules. If I drop ABS, I don't want the cluster alarms on, but if I were to re-install it, I'd want the cluster alarms to easily work again, so no permanent removal of the brake alarms in the cluster. Using tape to cover the LED is, er, tacky. I have no interest in the cost or complexity to implement Bosch or Teves.
Unless there are other ideas, a used unit from Hawks seems to be the best option. Anyone know a reliable resource to rebuild a spare OEM EBCM?
