Help gauges not working right
With that much craziness going on I would suspect the issue to be something that is common to all the symptoms. A bad or intermittent ground can cause a wide variety of crazy stuff to happen. Check all of the grounds you can find, disassemble and clean any corrosion you find. Reattach them and see if that helps.
- Animals chewing on wires
- Melted wires (touching an exhaust header, etc.)
- PCM water intrusion (unlikely unless the PCM has been disconnected without replacing the seal afterwards)
First things first - I'd shoot whatever is doing that. (They will keep coming back for a snack on the insulation.)
Usually, the wires in the bundle are differentiated by white stripes or other markings. If you are lucky, you might also be able to match up lettering/printing of wire information on the side of the wire.
In conduits where the same color wire is strung, those wires are usually different gauges. However; in this location for the ECU, you may have some identical wires and may have to undo the conduits/bundles to see which sensors and pins the wires go to.
