Sponsored by: CARiD
spark plugs
Old Jul 20, 2004 | 03:05 PM
95camaroz28's Avatar
Default plugs
Well i am in the market for some new plugs i have split fires in the car now(didnt put them in came with the car) I heard that split fires suck so.. what would you recommond for plugs and what is the best way to change plugs cuase i hear it is a 6 hour process??
Old Jul 20, 2004 | 04:11 PM
Vendetta's Avatar
I'm a big NGK fan. Shouldn't take 6 hours, but it'll take a good amount of time with those stock manifolds on. I usually go the ***** way and pay a mechanic to change my wires/plugs with my edelbrock shorties.
Old Jul 20, 2004 | 04:19 PM
96SCTA's Avatar
Go Bye A Q Qratched And The Job Will Be Done In A Few Hours.
Old Jul 20, 2004 | 05:21 PM
Gangly's Avatar
swivel joint, extensions, 3-4 inch piece of waterhose, and bandaids.
Old Jul 20, 2004 | 06:32 PM
why the hose
Old Jul 20, 2004 | 08:54 PM
BizZzatch350's Avatar
Moderator
I run TR55s, I wish I would have gotten TR6s.
Old Jul 20, 2004 | 08:59 PM
Snow Dog's Avatar
i run NGK TR55's. i dont have a reason for anything else. i also dont look for power out of my spark plugs. so i see no reason to pay for anything more than a good quality platinum plug. irridiums are fine too if you can stomach the cost. but split fires, bosch +4s, or any of these other plugs that claim to give you power increases i dont care about.
oh as far as doing the plug change. i hope you have a lift to work from. itll make life much easier. if not lube your arm up in something slipery so you can sldie it in between the engine and bay. if you arm is even small enough for that. just dont get stuck.
Old Jul 20, 2004 | 09:32 PM
i have small arms im only 17 . i have big hands but my wrist doesnt have a bigger circumfrnce than 4 inches. would a pit work???
Old Jul 21, 2004 | 08:11 PM
Snow Dog's Avatar
yeah thatll work good so long as its not terribly narrow. being able to stand under the car makes life easy. laying under it could work, but would not be fun
Old Jul 21, 2004 | 11:33 PM
1QwickLT1's Avatar
I did mine when i had my stock manifolds laying on my back......then again i gave up cuz it was REALLY tuff without a lift. My buddy had a 94 Z and he changed his plugs in 6hours, and if u have ever seen the stock routing of the wires...yeah, he didn't change them lol. I changed all mine when i got longtubes, and now they are like a 20 min job, and the wires (i got OVC wires) are real easy to run with longtubes also, just a little info if u ever think of getting headers.
-Dave
Old Jul 22, 2004 | 12:58 AM
TSAEB's Avatar
u stick the hose on the end of the spark plug...the hose works like a swivel/extension when u cant reach with ur hand...helps alot...the driver side can be changed from up top...other side go from under its alot easier...and 6 hour job depends on u...it took me about 2 hours the first time and now about 1 hour...of course i think girl scouts have bigger hands than me.
Old Jul 22, 2004 | 08:26 PM
pmbmax's Avatar
tr6 is a colder plug denso and ngk are backwards on their heat
Old Jul 22, 2004 | 08:42 PM
Cliff Allon's Avatar
Delco part # is R44LTS had desent luck with these
Old Jul 29, 2004 | 10:05 PM
transam93lt1's Avatar
how do you change the 8th spark plug by the passenger side near the fire wall with the stock manifold theres no room to stick your arm in from underneath? i changed them all besides the 8th one cause i couldnt do it
Old Jul 30, 2004 | 12:05 AM
97th_sign's Avatar
that one i beleive i got from the top but with a swivel and extension...that was a 97 lt1...as for the job taking 6 hours thats pretty funny...but then again im skinny so guess that helps...when i had stock manifolds i jacked the car up and pulled all the driver side from the top except for the number 7 plug which i got from the bottom, and the passenger side i got them form the top i think...as for the wires i had the shop that did my headers swap the wires since they were there...lol...now with my LT's i swap plugs in about 30 minutes (includes jacking and securing the car)..well good luck!
-Q
Old Jul 30, 2004 | 12:16 AM
Hambone 7's Avatar
i run splitfires (SF10D), they do alright i guess. friend got a few sets of them so i diddnt pay much of anything for them so i like em well enough. im switching to NGK's when these burn up.
Old Jul 30, 2004 | 01:14 PM
so you changed the 8th plug from uptop how? im skinny the stupid dipstick is in the way?
Old Jul 30, 2004 | 07:21 PM
Snow Dog's Avatar
i did mine from the bottom. no laughing but heres how.( note i have dual cats) get oil liquid dish soap. something that will lubricate your arm and stay on there. reach up and squeeze your arm past the manifold. hoook it back around and take the plug out. hey it worked for me. other than that drop the y pipe and try not to break a stud.
Old Aug 5, 2004 | 10:40 AM
ramairbrc's Avatar
The last time I changed plugs on an LS1 Trans Am, I changed them all from the top. 7 took me 30 minutes, the 8th took me 4 hours. I finally was able to clear enough stuff away to just get my hand, and a "shorty" ratchet in there. It certainly wasn't easy. And I'm getting ready to do it again, but this time on a different car - I've been putting it off for a couple months now.
