Sponsored by: CARiD
LS1 Running Funny and P0101 Code
Old Jul 24, 2021 | 07:37 PM
97LS1Formula's Avatar
Default LS1 Running Funny and P0101 Code
I have a swapped LS1 in my '97 Firebird with a truck MAF. My car runs funny. It feels almost like a "shudder", sometimes a lack of power and sometimes a hesitation. I did a log of when I had the problem and was told by two different tuners that there did not look like there is a problem. I am getting a P0101 code. The MAF and computer are fairly new from Summit Racing. I read that the PCV valve can be a problem. I went from the "fixed" type to the "rattle" type. Here's is what really gets me. Sometimes the Check Engine light goes out by itself and the car runs great then a little later the problem comes back. Does anybody have any suggestions?
Old Aug 2, 2021 | 03:44 PM
rv12's Avatar
I assume you know, but that code means the computer isn't seeing what it is expecting form the MAF. I'd assume a tuner would see this. Could be a bad connection or intermittent failure.
Old Aug 7, 2021 | 03:21 PM
Yes, I know that MAF isn't "outputting" right. The MAF is fairly new, so I don't think that it is the problem. One thing I did notice is that 2 connectors of the MAF are significantly smaller than the other 3, but the connector size is the same for all 5. I have to look into this more and to see if there is a way to test the MAF. Also, I am also getting Code P0481 (Cooling Fan Relay 2 Control Circuit). The fans appear to be working fine. I am guessing the Code is from the LT1 to LS1 swap. I have to look into this to see if maybe it is causing some kind of electrical interference with the MAF.
