Trying to fix A/C
My wife's A/C hasn't worked in her car since we got it (about 5 years ago). After the heatwave the NW got a month ago I decided I should try and get it at least somewhat working so she isn't melting. Went to Oreilly's and bought a recharge kit and started following instructions.
With the engine on and A/C set to maximum, the compressor isn't engaging. I've verified all relays are working and turning on (even tried shorting them just to be sure), so at this point I can only assume the pressure switch inside the compressor is what's causing it to stay off. What's weird though is that when I hooked up the recharge kit the pressure gauge pegged at maximum. I thought this odd considering the system hasn't run in over 5 years, but if the pressure is too high it could explain why the system isn't kicking on. What kind of fix is there for this? Or am I going to have to take it to a shop? Thanks guys.
I have a harbor freight set that works fine, I built an adapter to attach the disposable cans from the auto part store to it..
If its lost charge completely ,, you need to replace at least the dryer.. Pump it down with a vacuum pump ,, let it pump after it bases out for about an hour..
The vacuum pump will show if you have any serious leaks usually.. When you turn it off the gauge should stay where it is for quite a while.
If you have the ability,,, purge with nitrogen after the pump down then re-pump then charge.
They sell cans of R134 with a stop leek and a leak indicator you'll see purple where any leaks are..
Of course, it means evacuating and recharging the system anyway, so I'll probably go over all of it and replace other parts while i'm in it.
If it were engaging but slipping there is a shim in the clutch pack you can remove and get it working temporarily..
But if there is insufficient pressure or too much it will not start the compressor, the compressor and fan have dedicated AC relays..
At this point I dont think there is too much pressure, I think since the compressor isn't turning on the pressure in the system is just equalizing, which is why the shitty gauge on the recharge kit just pegged at maximum. Going to start with the coil/clutch and go from there.
Thanks everyone!
