Sponsored by: CARiD
SLP lid
Old Aug 28, 2021 | 05:00 PM
98_wssixer's Avatar
Default SLP lid
Hey guys I have a question about my SLP lid that has really been pissing me off. when I got the car I had already had an SLP lid installed and if I drive the car in heavy rain or take it in an automatic car wash the check engine light flashes at me and the car runs like **** due to misfire for a few miles after I’ve already tried new foam weatherstripping for the lid and a new air filter and I’ve sealed it up as good as I know how any other ideas?
Old Aug 30, 2021 | 01:05 PM
ss.slp.ls1's Avatar
Are you sure it's misfiring because water is getting into the intake? I would suspect a wiring issue that is shorting out with wet. When you do the automatic car wash, have you tried turning the car off while any water is flowing? If the misfire still happens, then it's unlikely that water is getting into the engine.
Old Aug 30, 2021 | 01:25 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I don't really see how the lid could be the issue here. Do you have a ram air kit installed, or if you have a WS6 (as your username suggests) have you removed the baffles in the hood (making it a true "Ram Air")? Those things might cause significant amounts of water to reach the air filter if it's sprayed at high pressure directly at the ducting. But there is nothing about the air lid itself which would lead to excessive water intrusion during a car wash.
It's also possible that water is leaking past the cowl and onto the intake manifold, seeping past the intake gaskets or even a bad fuel injector O-ring. The intake gasket issue has been covered in a few threads over the years; some folks have experienced hydrolock conditions due to this (but such typically happens only when the car has been sitting in the heavy rain and water keeps seeping into the cylinder withOUT the engine running to burn it off).
As mentioned above this could also be a wiring issue, ranging from an actual damaged wire to a marginal weatherpack connector or some other odd water intrusion issue that disrupts a signal or the ignition system in some way.
Based on what is known so far, I would assume that just about anything else is more likely that the lid itself being the problem.
Old Aug 30, 2021 | 02:14 PM
98_wssixer's Avatar
I guess the o ring or electrical problem never really crossed my mind so I’ll definitely do some checking around but I don’t know of any electrical problems it could be thanks for the reply’s tho guys and yes it is a 2002 T/A with the ram air package
Old Aug 30, 2021 | 07:25 PM
spdygon's Avatar
Must be Electrical…i have the SLP Cold Pack think that is what it’s called. Has the duct in front of the radiator and have been a very heavy rains with no running issues
Old Sep 2, 2021 | 12:14 AM
RevGTO's Avatar
Pontiacerator
All the suggestions above make for far more likely causes than your intake tract and lid. But when the problem occurs, have you checked the airbox under the lid for water puddling and whether the air filter is wet? Due to my CAI in heavy rains, I've had a little water in my airbox a few times and once the air filter a little bit wet, but never any problem because of that.
Old Sep 2, 2021 | 10:27 AM
98_wssixer's Avatar
The air filter does get a little wet but I didn’t think it’d be enough to make the car run bad I’ve opened the hood and let the car run as I sprayed the whole engine bay down with water in a spray bottle and don’t have any issues so that’s why I was kinda assuming a lid problem
Old Sep 2, 2021 | 01:08 PM
ghardester's Avatar
When this happens, have you pulled over into a sheltered place and took the air lid off and looked for signs inside of water? The air comes up through the filter, then into the lid, and then passes the MAF sensor. The MAF would be the first place that water could be causing drivability issues if water was getting either past the filter or from a leaky lid. The water should be obvious by just popping the lid open and taking a look. If the inside of the lid seems dry and the tunnel to the MAF is dry, then the lid is probably not the problem.
Take it to the car wash, try to create the issue, and then look inside the lid/tunnel, MAF area.
Old Oct 4, 2021 | 01:46 AM
98_wssixer's Avatar
The ram air hoods on both my 98 WS6 and my current 02 WS6 are debaffaled and both had SLP lids the only difference that I know of between the cars is that my 02 has the smooth bellow from the back of the lid to the throttle body my 98 did not I can see the factory ribbed bellow holding water from going in the throttle body does anyone think this sound like a idea to look into?
Old Oct 4, 2021 | 01:01 PM
RPM WS6's Avatar
No, that does not sound like an idea worth looking into IMO. Reason being that the bellow is after the MAF, and if enough water was getting past the air filter to puddle in the folds of the stock bellow, then you'd already be having some driveability issues due to a wet MAF anyway. So the problem would have to be forward of the bellow, or related to something else entirely as mentioned above.
Old Oct 4, 2021 | 02:12 PM
VIP1's Avatar
Copy & Paste Moderator
Is the bottom of the airbox missing or cut open? Some people do that to get some "under nose" air.
Old Oct 4, 2021 | 10:44 PM
98_wssixer's Avatar
the whole air box and lid looks fine to me no cuts or anything out of place the lid itself looks a little old and weathered but nothing that would cause this problem so I’m tempted to try a different intake and see if it clears the issue up I’m sure it’s something with the lid that I’m not seeing because I’ve wetted everything down under the hood and the car gave me no problems only when I’m on the freeway at about 65 - 70 in rain or water gets sprayed directly into the grills on the hood is the only time I can get the car to act up
Old Oct 6, 2021 | 12:02 AM
RevGTO's Avatar
Pontiacerator
But there are few conceivable ways that moisture could enter the airstream because of a problem with the lid. Perhaps if the lid was not properly seated on the airbox, but in that case the lid would have to be drenched with water on top and the air filter wet as well. Or the lid installed so cocked on the MAF that there is an air gap on the bottom where moisture gets sucked in.
Both of these are really absurd suggestions. Which is to say, I can't see your problem being caused by the lid.
Old Oct 6, 2021 | 08:26 PM
VIP1's Avatar
Inspect the bellows between the MAF and throttle body. Although a tear there should present running issues always and not just during rain.
