Sponsored by: CARiD
Engine overheating
Old Sep 2, 2021 | 09:47 PM
CatfishCamaro112's Avatar
Default Engine overheating
So I just put a new radiator in after the last one broke but then it needed a water pump, so I put that in yet it’s still overheating? Any helpful advice or tips are appreciated!
Old Sep 2, 2021 | 11:52 PM
pdxmotorhead's Avatar
Fully bled? I bought a vacuum bleeder system, its awesome. Easier than filling with a hose.
I've always had bad luck re-using thermostats or thermostats that have seen big heat..
Old Sep 3, 2021 | 11:56 AM
01CamaroSSTx's Avatar
Park the vehicle in a way that elevates the nose of the vehicle then slowly add coolant. Make sure the steam crossover line is connected correctly. You most likely have trapped air in the system and once all trapped air has escaped it should not overheat.
Old Sep 27, 2021 | 02:28 PM
imma_stocker's Avatar
If overheating while driving, be sure the air dam is in place. Assuming this is an f-body or vette that needs an air dam to feed the radiator.
