Sea foam
I run a bottle of [ Techron concentrate plus complete fuel system treatment | GM part # 88865595 | AC Delco 10-3012 ] through all of my recent GM engines about 4 times a year. That product (it's the same juice in all three bottles, only the labels and bottles are different) is actually recommended by GM in several TSBs relating to Fuel Gauge sender issues and fuel injector issues as preventive maintenance.
Other than that, I run TopTier™ gasoline in all my recent vintage GM cars (as specified in the owner's manuals).
Before I put anything in the tank or in the crankcase, or in the cooling system, I always read the SDS (Safety Data Sheet) first. Then I ask myself, "Self, why do I need to put ___{ingredient from SDS}________ in the gas tank?" I avoid products with "proprietary" contents. It's easy enough to keep your trade secrets and still tell everything that's in the product (along with maybe some things that aren't in the product).
As to Sea Foam specifically, why do you think it's a good idea to put Isopropanol (Isopropyl Alcohol) in your fuel tank? Or some mysterious "proprietary hydrocarbon blend?" And why would you add that to the crankcase?
I agree with everything Racer notes above. I would not pour any cleanser or detergent directly into the engine oil filler for fear of causing a sludge and varnish avalanche at the pump pickup in the pan. I do, however, run high concentrations of these products in my fuel tank and I also stick with Top Tier fuel. My favorite products are anything from Berrymans, AC Delco X66P, Chevron Techron and BG Products 44K Platinum.
And remember, these engines did not get grimy, sludged up and nasty on the inside overnight. You can't expect overnight remedies to work that quickly. Use Top Tier fuel and shorten your oil change intervals and you will eventually clean things up.
Rick
Disclaimer on this next part. This is something I've done for years of buying vehicles to resell, part out, or use as donors on my own projects. I wouldn't recommend you do this.
When I want to clean out an intake manifold, I usually do something much worse.
I keep a nasty blend of acetone, methanol, water, and muriatic acid and a couple of other things in a gallon jug that has a siphon tube going through the lid with a 24" long small diameter hose (windshield sprayer hose) that has a cone shaped barb on the other end.
I start the engine, hold it about halfway up to the limiter, and shove that cone shaped barb in any vacuum line I can find. Will smoke bad enough that people will consider calling the fire department, but after dozens of times of siphoning an entire gallon of this mix into the engine and then using borescopes to check the intake manifold, intake ports on the head, backs of the valves, and tops of the pistons with through the spark plug holes, there's usually a dramatic reduction in build up.
Just for kicks I toss in some parts store oil detergent before hand and let it idle/warm up before I do this. Then I change the oil.
Between the detergent and the siphoned mix into the intake, it can be pretty alarming the amount of things I see come out of the exhaust or pan drain.
It keeps fuel stable (Like the Stabil product) its a good top end lube preventing rust on the valves, and piston rings and cylinders when parked.
I doubt you find many commercial fisherman that don't use it.
I've run it when I had a engine that had issues like gummed up fuel system carb or injectors, I've also had a couple cars that started throwing secondary 02 codes, ran a can through the fuel tank and the codes went away.
I did this to a honda 1.6L and had a diag display plugged in,, the Sea Foam raises your exhaust temps about 300 degrees at WOT. and it causes the AFR to richen slightly, on the honda it was about a point richer on average.
I also checked the cat before and after and there was visibly way less carbon in the matrix of the cat. I also bore scoped the intake and
the valves were cleaner,, not perfect, but again a visible change.
Its not a rebuild in a can but IMHO its a reasonably effective product,
I use Techron in my modern vehicles, it doesn't raise the EGT as much and it seems to clean injectors a little better.
BTW for you Water/Meth injection guys.. In the Early 1900's a lot of the early Gasoline powered tractors used steam to boost their torque when pulling a plow.
My Grand father had a 1932 John Deer, it had a line from the radiator to the carburetor, and a lever on the dash to turn on steam. It also had a tank that held about a gallon of top end lube. The carb was a updraft Marvel carburetor and the tank said "for best Results use Marvel Mystery Oil to prevent cylinder rust" The oil was sucked in to the engine through a small pipe that fed in to the intake. That engine had Iron pistons and cylinders and was a horizontal 2 cylinder.
it would idle down to about 6 rpm and I don't think it turned much over 100 rpm ever.
Looked like this.
You started it by grabbing the flywheel and turning it.. Eventually we put a electric starter kit on it..
That flywheel weighed about 400 Lbs..
So water injection,, not real new tech..
You drama queens above are seriously talking out of your ***.
It's been used by the auto industry literally millions of times.
Police agencies, taxi companies, US mail service vehicles, you name it.
I am sure someone here will chime in who has a buddy, cousin, neighbor, etc that used seafoam and destroyed their engine, but I would take it with more then a grain of salt.
GM's X66P cleans much better than Seafoam. It cost a lot more as well. I wouldn't say Seafoam is harmful used as gas or decarbon treatment just suboptimal.
Many dealerships for other brands of cars like BMW & Mercedes were using X66P for de-carbon treatment when their own and other profressional chemicals failed to do the trick.
There's definitely more than one way to do the given task etc. However, X66P is the best I've seen in action and I've used dozens of cans of Seafoam over the years. If it's on sale not opposed to Seafoam as gas treatment etc.
When I installed a set PRC 225 heads on my LQ9 I wanted to clean the carbon off the piston tops. Soaking a 4" (paint) polishing pad with Seafoam then shoving it in each bore for an hour or so softened the carbon so I could just wipe it off. The 4" pad fits the cylinder perfectly making cleaning much easier.
As stated above seafoam has been used for decades, not just by regular people but by first responder mechanics across the country, taxi companies, construction companies, you name it, they use it.
Maybe the guy dumped 3 cans of it into his crankcase, or something else was going on, but Seafoam did not lock up his engine.
Nowthen, this is what Seafoam recommends...
- Add one ounce of Sea Foam Motor Treatment for every quart of oil in the crankcase. When ready, remove oil filler cap and pour the recommended amount of Sea Foam directly into the engine crankcase. Do not exceed one treatment per oil change interval.
