Sponsored by: CARiD
power steering pump
Old Feb 9, 2022 | 04:58 PM
95maroz28's Avatar
Just remove the valve, on mine its threaded in uses a regular socket.
I would bet its grunged up or the spring gave up.
You think if the power steering functions sometimes before reverting back to hard steering it maybe something up with the bypass valve? Does anyone know if the f-bodies socketed bypass valve is the same for c5 corvette?
Old Feb 9, 2022 | 10:40 PM
sjsingle1's Avatar
I believe the vette pump is a saginaw type 2....so the bypass valve should be the same....what pressure the valve is set at is unknown
Old Feb 15, 2022 | 04:59 AM
95maroz28's Avatar
Man just when i thought this couldnt get any better i took the car to get tuned this morning for the cam and headers. The power steering was hard to whole way even backing up on the dyno. The guy did 5-10 dynocom eddy brake dyno pulls tuning the car and 2 local drive trips with hp tuners to data log the car. After i got the car back started it and power steering was fully functional it functioned all the way home and the two seperate trips i took this evening. Not sure if there is air in the system or what. The only time it worked was when i replaced the hb which requires rack removal about a month ago.
Old Feb 15, 2022 | 09:09 AM
01CamaroSSTx's Avatar
It was air in the system that finally worked its way out. Have you checked the fluid levels again? You may need to add some now.
Old Feb 19, 2022 | 04:01 PM
95maroz28's Avatar
Yes its full i may have had more in the reservoir.
