Sponsored by: CARiD
Please help, column issues.
Old Sep 7, 2022 | 08:32 AM
Maj.Dripws6's Avatar
Default Please help, column issues.
Hey everyone! I had to make a new account can’t access old lstech membership.. just bought another fbody last week (00’ ws6 m6) it’s my 5th fbody so I’m somewhat familiar with the cars, but now I intend to keep this one forever. That all being said I get home it doesn’t start over the course of the next two days I replace the ignition switch and as I take it out to diagnose a second time after no start the ignition ROD fell completely out of the column I notice the headlight rod was also loose. I’ve watched many videos and been looking around on here, haven’t found anyone dig that deep into the column without just swapping it. I already have the column partially out to access the ign switch obviously as well as airbag remove. My question, will I be able to reattach the rod without removing the whole column after pulling the steering wheel, signal mechanism, clock spring etc. Could I possibly bypass the switch by putting it on a 3way toggle switch for the accessory and ignition start, possibly switch and push start to bypass the rod all together. Thanks for all input, this design is frustrating.
Old Sep 9, 2022 | 10:04 AM
wssix99's Avatar
Save the manuals!
This step-by-step guide should take you through the rebuild. Aside from the wires and clockspring for the airbag, just about everything on the F-Body is identical fo this guide. https://www.crankshaftcoalition.com/...ck_Rebuild.pdf
