Sponsored by: CARiD
02 TA engine light
Old Oct 18, 2022 | 07:04 PM
johnfin1's Avatar
Default 02 TA engine light
What does it mean when the check engine light flashes while driving the car?
Old Oct 18, 2022 | 08:29 PM
99 Black Bird T/A's Avatar
Usually that is indicative of multiple misfires...
Sounds like time to scan for codes and see what's pops up.
Did the car get a new cam or other mods?
Old Oct 18, 2022 | 09:15 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
^ Yep. Flashing SES can only mean one thing: serious misfire. You will likely see a DTC P0300 and a P030x (x = 1-8, # will correspond to the misfiring cylinder(s).
Old Oct 20, 2022 | 06:40 PM
johnfin1's Avatar
So it looks like I have a misfire on #4. Not sure what is causing that. My OBD codes are P0304 P0161 P0332. Was running just fine, now this. Any thoughts?
Old Oct 21, 2022 | 04:46 PM
LilJayV10's Avatar
Yeah, you need to diagnose your #4 cylinder misfire.
Old Oct 21, 2022 | 05:13 PM
I'd start with the simple stuff by swapping coils, injectors, plugs and wires from the #4 w/miss to a known good cylinder, one at a time.
Process of elimination. If the misfire moves to the good cylinder you'll know the swapped part from #4 is the likely culprit.
Also inspection of #4 plug may give some clues depending on how it looks.
Chasing a misfire one time, discovered the cause was the spark plug insulator was cracked. Replaced plug and end of misfire issue. So now I like to check misfiring cylinder's spark plug early in the process.
