Overheated to 250 degrees
FWIW - that coolant line to and from the throttle body is sometimes a leak source that easy to forget to check. Folks seldom replace that line when doing hoses etc. Likewise for small return lines.
Hopefully you just have something loose. Given your temperature and what sounds like a small leak that isn't holding pressure. I'd fill the system and rent a pressure tester. https://www.autozone.com/loan-a-tool...ressure-tester
If you manually pressurize the system with the engine off, hopefully the leak and issue should make itself evident to you.
My first thought as well when I read the initial post. If the coolant is freezing at 10°F then it's pretty weak (mostly water), I think you should be good down to about -35°F with 50/50.
Also alarming that it was so low on coolant in the first place. Where did it all go if the puddle was small? Is it perhaps burning coolant?
I will say that I got used to the feel of my C6 and damn are those two different animals.
