02 Chevy Camaro throwing these codes. Need help.
My 02 Chevy Camaro SS is sick, and throwing these two codes together,
P0101
P0342
Tach will also quite on the dash as well,
I'm worried, as I have just dumped $1300 into replacing both catt's. This issue was present before catt replacement.
Car has 198,000 miles and runs fine.
I'm worried it might be a timing chain issue or the cam position sensor is dying (both expensive repairs)
What are the Possible Causes of the Code P0342?
- Faulty Camshaft Position Sensor
- Camshaft Position Sensor harness is open or shorted
- Camshaft Position Sensor circuit poor electrical connection
- Faulty starter motor
- Starting system circuit
- Dead (Weak) battery
What are the Possible Causes of the Code P0101?
- Dirty Air Filter
- Dirty Mass Air Flow (MAF) Sensor
- Intake air leaks
- Faulty Mass Air Flow Sensor
- Mass Air Flow Sensor harness is open or shorted
- Mass Air Flow Sensor circuit poor electrical connection
