Sponsored by: CARiD
What other things to do while intake manifold is off?
Old Feb 24, 2024 | 09:58 AM
cascadesys's Avatar
Default What other things to do while intake manifold is off?
Removed my intake manifold to replace my knock sensors. Was a bit of a pain, but got it fully removed and deep cleaned the intake manifold itself with degreaser and brushes in a tub. I cleaned the valley cover and intake ports area. Anything else I should be doing while I have this apart? I’ve considered doing the LS6 valley cover but I don’t really have a huge oil consumption problem and I recently installed a catch can, is this worthwhile? Any other suggestions? Mostly stock 2001 WS6
Old Feb 24, 2024 | 10:57 AM
BFromTheD's Avatar
Unless youre going to also be pulling the heads I would say no. Try to make sure you get as little dirt and dust down into the short block and intake ports.
Old Feb 24, 2024 | 12:45 PM
LilJayV10's Avatar
Cam sensor O ring.
Ls6 valley cover if you don't have to modify the block. I had to on my 2000, but I "think" the later engines are different, but I'm not 100% on that.
