Sponsored by: CARiD
2002 LS1 power steering issue
Old Mar 10, 2024 | 12:18 AM
Pharsider's Avatar
Default 2002 LS1 power steering issue
Hello guys having a power steering issue. I just replaced the power steering pump & power steering pump pulley. Already filled up with fluid and still the steering wheel feels super stiff like the car doesn’t have power steering. Had this issue before which is why I replaced the pump and pulley in the first place. Had the front of car jacked up and was turning wheel full lock left and full lock right to try and remove any air in the system. I kept an eye on the reservoir and it seemed like air bubbles were definitely coming out. I was doing this for about an hour and the fluid level was not changing so I thought it might have been fully bled of air. After jacking the car back down and starting it, had the same issue of the car feeling like it didn’t have power steering. Weird part is that from inside the car while turning the wheel I can hear a sort of hissing noise coming from the steering column when I turn the wheel near full lock in both directions. Anyone experience this before?
Old Mar 10, 2024 | 12:28 AM
sjsingle1's Avatar
what brand pump are you using ?
